Old Thu, August 11th, 2011, 06:50 PM
God & Guns
Ok, what's the best way to manually turn the engine? Don't you have to do something to let the pressure out..or does it go out the exhaust valves? So what is the coolant plug for? Would it be any use when draining the coolant?
