Old Fri, November 4th, 2011, 12:16 PM
IF you have made changes to the tune using the Custom Options Menu, then "Load Previous Settings" recalls and applies the last values you used in each of the options, NOT the settings Bill applied. If you did not change an option, then the original value in your custom tune is applied.
Like 88Racing said, don't go changing things willy-nilly. Make sure you understand what and WHY you are changing them. If you are not careful, you can easily counter some of the benefits Bill has given you in your tunes. And, none of us are really qualified to tell you what will or will not improve (or hurt) things. Every truck and driving situation is different.
