Old Tue, November 15th, 2011, 11:06 PM
Sweet truck!
BTW asking$?
I would be willing to sell the truck with or without parts that are listed in the add, so the price can vary greatly depending on what you want on it.
Originally Posted by ticopowell View Post
Ill trade you for my 2002! lol ... If I could afford your truck I would buy it for sure... :/
I am curious as to why are you selling it?
Need to finish my house....lol.
I tallied up some of the extra's on the truck:
Engine:
Block Filled to 2" from deck (have no cooling issues, oil temps stay normal even when towing 14K)
Crank turned .010 under on both rod and main journals
Clevite 77 bearings
Main Girdle and ARP main studs - $1000
Crower Billet Rods - $2,700
Mahle pistons machined to match deck height and valve reliefs cut to accommodate cam - $1200
Rotating assembly balanced to 1 gram
Heads are ported and polished, new cups, bronze valve guides, hard seats, Clevite 77 valves, and are machined to accept the FireRings with a 25RA finish - $500
H-11 head studs - $795
WOP cam - $750
WOP valve spring kit installed at ~1.86 - $500
WOP FireRings - $500
SmithBro's chromoly pushrods - $225
Stealth twin HPOP's - $1200
Dieselsite reservoir spacer - $225
Dieselsite 203* thermostat - $35
Dieselsite coolant filter - $100
New oil cooler
Air: - $7000
TN 88mm ball bearing primary
TN 66mm ball bearing secondary
Both stages intercooled
Both stages gated using RG-45 gates
TN wastegate controller
AFE Pro7 filter
Fuel:
Swamps 300/200% hybrids - $2250
Fuelab 42401 - $500
ITP 5/8 pickup tube - $50
Aeromotive Hex Drive regulator - $200
4 port feed using 3/8's lines
Transmission:
Suncoast billet input shaft - $300
Suncoast clutches - $500
Transgo Tugger 2 kit - $150
Banks billet triple disk converter (stock stall) - $900
Stereo:
Kenwood DNX 7100 HU with GPS navigation - $500
Alpine H700 Processor - $250
Focal 165K2PUV (components) - $700
Image Dynamics IDQ12V3 (sub) - $280
Sundown Audio SAZ-1000D (1000 watt sub amp) - $280
Sundown Audio SAX 100.4D (100X4-channel speaker amp) - $320
Custom sail panels tweeter pods
Custom center consul sub box
Custom amp rack with fiberglass/carpet fascia
Kunukonceptz Krystal Kables - $50
All 4 doors sound deadned inside and out - $200
Lighting:
Projector HID conversion - $200
4 foglite's
KC backup lights
ProComp driving lights (135w) on custom light bar
The rest of the truck:
05 conversion -$1300
Gooseneck Hitch
Firestone Air Bags - $300
Truxedo Slim tonneau cover - $450
Diprocol EGT, boost, and trans temp gauge - $250
Autometer boost (primary), and backpressure gauge - $80
Aeroforce ScanGauge - $200
100 gal auxillary fuel tank with transfer pump - $500
Greddy turbo timer - $100
140 volt IDM
200 amp alternator - $200
Total : $27,440
Add that to a truck that is worth 14K....
If someone wanted to buy this thing and part it out, that would turn a real nice profit!
