Old Fri, December 23rd, 2011, 12:33 PM
The following two shots are the torque curves for each. The diesel graph was emulated from an existing 400 HP dyno run while the gasoline graph was transcribed from Desktop Dyno software. Again, the diesel is on the left and the gasoline engine is on the right. Don't get too bent out of shape as to what seems to be a much flatter, more broad torque curve on the gas engine because the RPM axis covers twice the ground and it affects the way the curve appears.
