Old Tue, March 10th, 2009, 07:46 PM
A couple things:
Did you return to stock before going to the dealer for service? It sounds like you didn't.
If you did NOT return to stock, follow these steps to see if you're OK...
1) Disconnect and then reconnect the unit in with the Key On. Make a note of the HEX code displayed on the screen.
2) Go to the Main menu, select Diagnostics and then Tech Support.
3) From the Tech Support menu, go to Version Info.
4) On the second screen in Version Info, make a note of the current vehicle HEX code.
5) If the 2 HEX codes match, you are in good shape. If not, then you'll need to contact us so we can restore your unit to an unused condition so you can start over.
Until you confirm that the calibration code in the PCM has not changed, DO NOT TRY TO PROGRAM! You may disable your vehicle/PCM. Not unrecoverable, just inconvenient.
Hope this helps.
