Old Tue, January 31st, 2012, 08:39 AM
Punisher's Avatar
Punisher Punisher is offline
Punisher is on a distinguished road
Help Cab Heat & A/C - Gryphon Programmer
OK... I've done several searches to see if this was an issue reported previously but haven't been able to find anything. I've searched keywords: "heat", "heater", "temperature", "thermostat"... all to no avail.
So... if it is somewhere please just provide a link. If not... here's the problem...
In short, whenever I have my PCM with stock tune, the in-cab temperature select works incrementally as one would expect. When I have a custom tune loaded (currently 87 Performance), the heat is either off, or on high. There is no gradual mix as I turn up (or down for that matter) the temperature select dial.
I return to stock programming and the temperature select goes back to incremental control.
Just to be clear... I'm referring to the climate temperature control knob in the center of the dash between the fan speed and venting select knobs.
Any ideas? This isn't so much a problem during the hot summer... but during winter it'd be nice to have the windows up without sweating or drying my eyeballs. Just seems odd to have to adjust the in-cab temp with the windows instead of the temperature control.
Thanks,
Rich
Before you try and beat the odds... make sure you can survive the odds beating you!
