Thread: adrenaline hpop
Old Thu, February 16th, 2012, 11:08 PM
Oil usage is determined by intensifier piston area, plunger travel, and nozzle size.
Basically, split shot injectors waste a good bit of oil because there is a period of the injection event where oil is being used but no fuel is being injected. Couple this with a relatively small volume of fuel to begin with and the excessive injection pulse width that is required to empty an AB or AD injector and you have injectors that KILL HPO. There aren't problems under normal usage to tunes <80 HP in most cases. However, tuning that maxes out the injectors' capability (100 HP or so) really begins to show shortcomings because of this issue.
That's why hybrids and singles with larger nozzles are da' bomb. Hybrids have a smaller intensifier piston (basically use about 72% of the oil volume that stock injectors use per given amount of plunger travel) and larger nozzles allow a greater amount of fuel delivery in a given amount of time compared to stock nozzles. 300 RWHP with stock nozzles on stock injectors is WAY different than 300 RWHP with larger nozzles as far as the tuning is concerned.....and that USUALLY results in the ability of a HPO system to maintain pressure above and beyond what's possible with stock splits.
