Old Mon, February 20th, 2012, 10:09 AM
God & Guns
That's good to hear from someone that has tried both. DP is overpriced imo. Most guys at TDS push DP hard. I put in a good word for PHO every chance I get.
You know you can combine the Whisper tune with any other tune (see my sig). Only thing that changes of a performance tune is the idle. When you press the accelerator, everything goes back to normal. FYI in case you wanted another tune.
