Old Wed, February 29th, 2012, 11:21 AM
WVOEX WVOEX is offline
WVOEX is on a distinguished road
Originally Posted by muns53 View Post
I can't add the Hellwig bar because it doesn't fit with my undercarriege supplemental fuel tank. So, I'm hoping the Ford 30mm piece will fit because it mounts to the axle differently.
Muns,
Just curious, did you ever try the 30mm Ford sway bar and did it work? I also have a WVO system, tried the Hellwig and no dice. I have a big Racor 1000FH filter housing on mine and it's in the way of the Hellwig. I'd be very curious to know if the 30mm worked for you.
My Ex needs serious help with the wander issue. I've replaced everything up front, sway bar bushings, drag links, steering box, ball joints, etc. I've added RAS. Now I'm thinking I may have to try the V/B code spring swap.
