Old Fri, March 13th, 2009, 05:32 PM
Dixie Design's Avatar
Dixie Design Dixie Design is offline
Warranty Voider
Dixie Design is on a distinguished road
It's a dual fan kit with dual, fully independent and adjustable controllers. The way it's setup it has a "Low Temperature" fan and a "High-Temperature" fan automatically controlled in a "staggered" turn-on arrangement to provide proper cooling under any condition. That also keeps the start-up amperage draw to a minimum. Should one of the motors give out, heaven forbid, it wouldn't leave you high and dry, you could still get home. The other kits, including FAL's, and piece together kits would leave you overheated and stranded should a fan fail. Other kits also mount THROUGH the radiator, eventually leaving holes and requiring a new radiator in the long run. Troyer's put together a custom fabricated mounting system. These are the reason I went with Troyer, might be more expensive, but WELL worth the extra mile they've gone in research and manufacturing.
Specs: 2004 4.6L SCAB | Gryphon Programmer 87 Performance | Magnaflow True Dual Exhaust - Rear Cat Delete | S&B CAI | Summit Underdrive Pulleys | Troyer eFans (ordered) | Smittybilt Bullbar | Procomp 6" Driving Lights | UWS Toolbox | Rhino Lining | Chrome Steprails | 2.5" Leveling Kit | 265/70/R17 Goodyear Wrangler AT's
Vids: Magnaflow Startup & Revs - Interior Exhaust Sounds
