Thread: Leaky Up-pipes?
Old Thu, April 5th, 2012, 06:45 PM
God & Guns
28psi is a little low choy that its good to go that high)...should see 32psi with a performance tune. Have you done a boost leak tester to make sure you have no leaks? I think you could also do a exhaust leak tester....and spray some soapy water on the up pipes and look for bubbles. Up pipes should be a rusty redish/brown color. I have a 3" body lift so I can see pretty goodcway back in the back.
Any other miss than a tuner? Exhaust?
