Old Tue, April 24th, 2012, 04:19 PM
Especial86 Especial86 is offline
Especial86 is on a distinguished road
Originally Posted by Virago View Post
The device itself functions. When programmed the truck stalls out/check engine light/wrench appear in tow or extreme. Tech said mass air impacted by the air intake. I updated with Fusion...still no luck.
Tech said to talk with Bill at Powerhungry Performance or replace factory air intake.
Have you tried cleaning the MAF "mass air flow sensor" with MAF cleaner??
If the intake is suspect, that's the first place I'd look. Also, look for leaks on the intake piping leading to the throttle body...
Try checking the codes with the edge and report back.
