Originally Posted by PerpetualSeanX
I look into the connections you mentioned for sure. Could you give me some more information on it? What exactly makes it worth the extra $100? What does it do exactly?
Item#:
28-1812S
Notes:
Manufacturer Info:
Granatelli
DESCRIPTION:
LFP HIGH OUTPUT Coil On Plug Connectors (3 Valve)
The LFP High Output solid stainless connector cables Coil-on-Plug connectors features a 3/16 solid stainless steel core, 500 degree Silicone Spark Plug Boots and an unheard of -0- Ohm resistance per foot. This patent pending technology has less RFi/Emi interference than O.E. and allows full coil power to reach the spark plugs. In house and independent Dyno-tests and long term road tests have shown various horsepower increases, improved acceleration and smoother idle that results in an overall better performing vehicle. The kit provides a custom tailored fit and is easily installed in less than 1 hour with basic hand tools.
Tested & Proven on our personal Mustangs for over 13 Months
Fits 2004-2007 3 Valve Modular Motors
Direct OEM replacement, won't void your factory warranty
Improves mileage and throttle response
Patented* design feature improves spark, 0 ohms of resistance, no radio interference
Includes all necessary hardware
