Old Fri, May 11th, 2012, 10:29 AM
Stealth Stealth is offline
Stealth is on a distinguished road
I'm not showing any codes stored on the tuner. Before the tune adjustmest and after the header install I got a couple of cat inefficiency codes with a light on the dash. I had bill adjust the tune to turn off. The rear o2's so the codes wouldn't come up. Since I knew the cats were small I put on the larger magnaflow cats. Never had an issue before with inspections and bills tunes. So will I be ok setting to stock for the inspection after drive cycles???
