Old Fri, May 11th, 2012, 11:10 AM
Originally Posted by Stealth View Post
I'm not showing any codes stored on the tuner. Before the tune adjustmest and after the header install I got a couple of cat inefficiency codes with a light on the dash. I had bill adjust the tune to turn off. The rear o2's so the codes wouldn't come up. Since I knew the cats were small I put on the larger magnaflow cats. Never had an issue before with inspections and bills tunes. So will I be ok setting to stock for the inspection after drive cycles???
Just leave the custom tune loaded.....reset pcm....do the drive cycles....
your programmer cannot read if the tests have cleared...there's another scan tool for that....
