Old Thu, May 17th, 2012, 09:42 PM
Lilpooh Lilpooh is offline
Lilpooh is on a distinguished road
Default New 6.0L FICM Programmers
With the Gryphon FICM programmer you don't need to send in your FICM. This programmer has all 4 FICM power levels at your disposal to swap in and out as many times as you want. It's also a monitor to watch up to 4 different parameters.
Very simple to use and load FICM tunes. Takes less than 2 minutes from start to finish. To load FICM tunes, remove FICM relay, plug into OBDII port, follow in screen instructions, turn key on, then off, it will ask you to remove the FICM relay if you didn't allready, select one of the tunes, download takes about 30 seconds, install FICM relay. There all done!
If your ready to order the Gryphon FICM programmer, it's easier to fill out the order form on their website. They process the orders in the order they come in.
If you have any other questions, just post up.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ,QT,GH,ID,head studs,II Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,Snow Perf stage II,EGR delete,AD2,4" turbo back straight pipe,K&N intake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod
