Old Tue, May 22nd, 2012, 08:49 PM
Enrique Enrique is offline
Enrique is on a distinguished road
the ficm programmer has nothing to do with ecm tuner, it only programes the ficm. as long as your superchips flashpack is'nt already reprograming the ficm then you should be safe to use both at the same time. some programers/tuners as i understand it should not be used in conjuction with the ficm programer, and i'm sure someone on this forum could tell you if you can stack yours safely or not.
