Old Mon, June 11th, 2012, 06:27 PM
Hoat Hoat is offline
Hoat is on a distinguished road
I think I have the correct sticker I want to make sure I have the correct PCM code.
It has the 12B599 and since its made in brazil I think its the same and the pcm number is 7FFA0. I can not find a 4 digit code.
the below is copied from the php website
On the side of the PCM connector facing the driver's fender, there is a white sticker that contains the Part Number and Calibration information. The Part Number is easy to identify because it will always contain "-12A650-" in the middle of it. The Calibration code (also called the "Box" code or "Tear Tag" code) is a 4 digit code that is composed of 3 letters and 1 number.
In this example, the PCM Part Number is "F81F-12A650-BF" and the Box or Calibration Code is "XLE4". For reference, the "DPC-402" is the hardware designation and is used to identify the Circuit Board used in the PCM. In the event a replacement PCM is needed, any PCM with a matching "DPC" number can be used, although you will need to have the PCM reflashed to the proper Calibration code.
