Old Tue, July 3rd, 2012, 11:46 PM
Originally Posted by toad View Post
In my mind I would think that adding extra fuel would allow my egts to be to high. Am I right in this thinking? Or does it come down to tunes? I just dont want to drop 1500 bucks on injectors and tunes only to have power that I cannot use.
Extra fuel = more heat. If you use the truck nearly exclusively as a tow rig, stick with stock injectors. If you install higher capacity injectors, any additional power you make over what you have now will just cause you to keep a close eye on your pyrometer. Stage one injectors will run identical to the injectors you have now unless you have the tuning changed to add more injector on-time......which will cause more heat.
