Old Fri, September 14th, 2012, 09:31 AM
Originally Posted by widj64 View Post
I just got the tunes today
2006 F150 5.4L supercab 6.5ft bed with canopy, magnaflow exaust, K&N CAI, gryphon tuner 87 towing and I get 7.85 at 0 60 is that ok?
the canopy is quite heavy and I have some camping gear in the bed, how much would I gain removing the canopy and else?
since I changed the rear brakes with ventilated drilled brakes I can't burn the tires while braking anymore.. any suggestions?
Put smooth rotors back on and put drilled up front.
Add more power/gear lower/much smaller tires.
Less braking. You shouldn't need to use too much brake pedal to burn the back, especially with the 5.4.
