Old Tue, September 25th, 2012, 08:16 AM
grec-o-face grec-o-face is offline
grec-o-face is on a distinguished road
Do you have a way to read scan data (particularly the exhaust backpressure data)? The PCM calculates torque (and subsequently transmission pressures) based on this reading. If you have a sensor/wiring issue or a plugged feedback tube, the PCM will default to pre-mapped tables and will make the necessary adjustments based on stock power levels. On a 49-state truck, the check engine light will not turn on in most cases.
I was hoping you'd see this thread. I also posted on FTE - there seems to be a lot of traffic there... Here's the link
Yes I do. I don't have AE, but my Aeroforce gives me some info. I checked my EBP against Baro with KOEO and they were a match at 14.
Yesterday I experienced a different issue. I attempted to switch to the Whisper and nothing happened. No change. I switched back to DD, then to Whisper again, still nothing. Tried HI, nothing. Then again... everything worked as it should...
