Old Fri, October 5th, 2012, 12:07 PM
AeroEngr08 AeroEngr08 is offline
AeroEngr08 is on a distinguished road
Jack, thanks for the suggestions but unfortunately my tuner isn't working how you describe. I get the flash screen at start up, I do not get the disclaimer as described, and it only displays the FICM strategy before I press enter. And you are also correct in that I don't see "Data Stream Read", "Data Stream Options", and "Version Info" under Diagnostics. I'm starting to wonder that since the programmer is set up to work with the FICM that it doesn't talk to the ECM/TCM and therefore doesn't give me the option to pull their strategies. I may have to get Bill to help me switch the Gryphon to the normal ECM diesel tuner before I see those options unless someone else can think of something I'm missing.
