Old Tue, October 16th, 2012, 06:43 PM
boto boto is offline
boto is on a distinguished road
Help Pegasus update/ custom tune installation
I see from the part number in your <a rel="nofollow" href="http://forum.gopowerhungry.com/profile.php?do=editprofile" target="blank">User Profile</a> that you have the older monochrome Edge Evolution (or Gryphon), rather than the full color screen CS/CTS platform. Edge Products| Product
So, you will use Pegasus, an app written by PHP to load your custom tunes, not the Fusion app from Edge. And, Pegasus does not have the "update problem" that Fusion has.
So:
1. Download Pegasus and install it on your PC.
2. Using your Gryphon, set your truck's tune back to stock (Level 0).
3. Remove the Gryphon from your truck, but DO NOT connect it to the PC yet!
4. Start Pegasus on the PC.
5. With Pegasus running, plug your Gryphon into the PC. This should cause the correct drivers for the Gryphon to load.
6. Once Pegasus recognizes your Gryphon, its screen should change from red to green and Pegasus should report that it is "connected".
7. You can then click on [Updates]->[Gryphon Update Manager] to load the current firmware from PHP into your Gryphon and make it ready for the custom tunes when you are told they are ready.
8. Disconnect the Gryphon, take it back to your truck, turn the truck's ignition to ON, and plug the Gryphon in.
9. After the Gryphon boots, you should be able to reprogram your truck to any canned tune you want.
I've tried to make this as explicit as possible. You can print it out to avoid problems remembering. You also have both the hex code and serial number in your <a rel="nofollow" href="http://forum.gopowerhungry.com/profile.php?do=editprofile" target="blank">User Profile</a>, so you need not re-enter that information.
Jack,
Today I got an email saying my custom tunes are ready. I clicked on my Pegasus update client and chose to apply updates. There were 3. One of them gave an error. Should I proceed as you instructed the other user you replied to above, or try to resolve the error? ...or something else?
-Doyle
an old "WSMR met. ranger" Feb75-78
'06 F150 XLT 5.4L 4x4 S cab, K&N, Flowmaster, bags, Gryphon 87 tow, 91 tow, 87 perf. 22' GearBox toyhauler.
