Old Mon, February 15th, 2021, 11:48 AM
I was able to push the .NET requirements back to 3.5 SP1, which is XP capable, and still get HydraFlash to build.
When you have a second, hook up to the interwebz, run HydraFlash, and let it update. You should be good to go after that and can then disconnect from the "Big Brother Broadcasting System".
Obviously, if you want to pull files form the Hydra Server you'll need a connection, but you can otherwise handle everything offline.
Let me know if you have any further issues. In the meantime, I'm going to look over those Excursion files.
Thanks!
