Old Fri, February 26th, 2021, 07:06 PM
I got the 3 gallon fuel tank mounted which also came with stainless braided line and AN fittings. I just knew there was a reason I never used that line or those fittings. What a pain in the butt. They're on there for good though.
Anyway, the supply line is done, the pump is mounted, the filter is mounted, and the return line is a 3/8-5/16 barb adapter away from being done.
The radiator hoses are also done. Well, the FE ones anyway since every other engine family will take a different set of hoses. The upper radiator hose is a lower 99-03 7.3L lower hose with four inches cut off of one end. Funny how that works out.
