Old Wed, June 2nd, 2021, 04:47 PM
Originally Posted by jjaj823 View Post
I'm not sure if you are aware, but clicking through the menu as described above doesn't do anything. I assume that clicking on the appropriate driver version should launch the setup? If so, that is a bug...the menu is there, but clicking on the driver version (*at least for the 64-bit Win 10) doesn't do anything.
I was able to get the driver installed manually by browsing through the software directory and clicking the driver version I needed though.
If there is a more "official" way you would like me to report potential bugs, please let me know!
Jeremy,
Thanks for letting me know. That's really odd as it works on our computers here. I'm wondering if it's a permissions setting that is blocking the Orion application from starting another application in the background.
Did you happen to try the shortcuts from the [Start] Menu? Let me know if those work. I won't hurt to reinstall the drivers, or at least start the installation and then cancel out of it.
As for the Parameter file uploading, it did successfully. I will provide a notification window that confirms that the file uploaded correctly, so there isn't any guessing about it.
I'll get a calibration over to you in the morning for you to load at your convenience.
Again, thanks for the feedback. This is the correct place to provide information and address any concerns, so feel free to post.
