Old Fri, September 17th, 2021, 07:04 AM
Absolution Absolution is offline
Rattletrap driver
Absolution is on a distinguished road
Originally Posted by Veedubfreak86 View Post
What pump bracket are you using for the dual SD pump’s
It's an eBay 044 dual. Some sellers let you order the thicker rubber for the thinner super duty pump. I just made the reducer from some rubber I had laying around.
Downside, it doesn't have a real mounting hole so I had to drill in the center of the bracket. It also requires the 044 check valves and some aluminum crush washers for sealing.
If I did it again I would go with a single AEM 400lpm and just keep a second one it cab.
The single AEM will support the same, if not more, than the dual super duties It requires less space and less fittings.
Only reason I originally went with duals was redundancy.
