Old Mon, October 11th, 2021, 07:27 AM
Absolution Absolution is offline
Rattletrap driver
Absolution is on a distinguished road
Originally Posted by syntaxterror View Post
Hi Absolution
What road ranger transmission are you going to use?
Any used RTLO 13 speed to be honest. Just so long as it has a sae-2 bell housing which I found a company that will find and install the correct bellhousing from their yard. The one in looking at currently is a RTLO-16713 mainly due to it having a PTO pump on it already.
I ordered a oem 206ss (FP62062RS2) bearing which im going to check and make sure it's the correct inside diameter 1.18".
I'll probably also have to get the drive shaft shortened.
There is a guy on the trucker forum who convert his dt466 to a RTO6613. His was a complete drop in from a 6plus.
Edit: if you have an automatic there is a chance it's an sae-3 bellhousing.
