Old Wed, November 10th, 2021, 07:40 PM
Corrected File.
Keep in mind... Much has changed in the last 10 years. With the release of the Hydra chip, we've switched everything over to the 256K format. It's easier to deal with and the files are handled in a logical addressing and bank format that is similar to the structure of the PCM. The old TS chips used a 224K format and bank structure that really wasn't the best approach.
This attached file will only work with the appropriate 256K definitions. If you're using the 224K-based definition, the file will load into the software and the emulator, but the visual representations in the software (Maps, Parameters, Functions...) are going to be jacked up due to the addressing difference between the formats. This means you won't be able to actually live tune the file until you get the correct definition.
I'm out of the office until Monday (having knee surgery tomorrow). If you want to catch up with me then, we can get that part resolved.
