Old Wed, November 10th, 2021, 08:01 PM
Powerstroke Cowboy's Avatar
Powerstroke Cowboy Powerstroke Cowboy is offline
Big Sky State!!!!
Powerstroke Cowboy is on a distinguished road
Corrected File.
Keep in mind... Much has changed in the last 10 years. With the release of the Hydra chip, we've switched everything over to the 256K format. It's easier to deal with and the files are handled in a logical addressing and bank format that is similar to the structure of the PCM. The old TS chips used a 224K format and bank structure that really wasn't the best approach.
This attached file will only work with the appropriate 256K definitions. If you're using the 224K-based definition, the file will load into the software and the emulator, but the visual representations in the software (Maps, Parameters, Functions...) are going to be jacked up due to the addressing difference between the formats. This means you won't be able to actually live tune the file until you get the correct definition.
I'm out of the office until Monday (having knee surgery tomorrow). If you want to catch up with me then, we can get that part resolved.
Bill. Thank you! I will get back with you at a later date to get the correct definition. What the best way to get a hold of you? My definition would be from when I bought to stuff about 9-10 years ago. I was wondering if maybe that was the problem since the QH was not supported when I bought the tuning package from you.
I hope all goes well for you in surgery and a speedy recovery!
EDIT: I bought the package from you back in June of 2012.
2008 6.4L, CCLB, 4x4, BD tap shifter, Intake, Exhaust and tunes 316,000+ miles.
1997 7.3L, CCLB, 4x4, ZF6, 300/200, twin HPOP, 6.0 IC with 3.5 IC pipes, E-Fuel, HX55 Turbo, 240,000+ miles Tuning by me.
Minotaur user.
