Old Thu, December 30th, 2021, 09:56 AM
Power Hungry Power Hungry is online now
Originally Posted by Powerstroke Cowboy View Post
Bill, have you tuned any pickups with pulsars GTP38R turbo? If so how has it done?
I have not specifically. However, one thing you want to do with tuning any larger turbo is back the ICP and timing down a touch to help get the turbo spooled. Too much ICP and/or timing at low RPM tends to reduce the amount of heat energy in the exhaust and makes the turbo a little laggy off the line. Reduced timing helps low end torque and improves the spool of the turbo. Once RPMs come up, normal timing and ICP curves are fine.
