Old Thu, December 30th, 2021, 11:44 AM
Powerstroke Cowboy's Avatar
Powerstroke Cowboy Powerstroke Cowboy is offline
Big Sky State!!!!
Powerstroke Cowboy is on a distinguished road
I have not specifically. However, one thing you want to do with tuning any larger turbo is back the ICP and timing down a touch to help get the turbo spooled. Too much ICP and/or timing at low RPM tends to reduce the amount of heat energy in the exhaust and makes the turbo a little laggy off the line. Reduced timing helps low end torque and improves the spool of the turbo. Once RPMs come up, normal timing and ICP curves are fine.
Thanks Bill. So I guess no data show what it is capable of. I am sure must folks are scared of the knock off version. After all, it can be had for under 900.00.
2008 6.4L, CCLB, 4x4, BD tap shifter, Intake, Exhaust and tunes 316,000+ miles.
1997 7.3L, CCLB, 4x4, ZF6, 300/200, twin HPOP, 6.0 IC with 3.5 IC pipes, E-Fuel, HX55 Turbo, 240,000+ miles Tuning by me.
Minotaur user.
