Old Mon, August 8th, 2022, 12:02 PM
Just to let everyone know...
There are 5 levels of brightness. If you hold either button for 2 seconds, the LED will change in response to the button you're pressing. The default when first connecting the Hydra should be level 5 which is the brightest position.
Also, when using the buttons to change levels, make sure you just give it a quick tap up or down. We occasionally have folks reach out with concerns that their levels aren't changing. This happens if you hold down the button too long.
It breaks down like this:
A button press of 0 to 500 milliseconds (up to 1/2 Second) = Level change
A button press of 500 to 2000 milliseconds (between 1/2 Second and 2 Seconds) = No action
A button press of 2000+ milliseconds (2 Seconds or longer) = LED Brightness change
I hope this is helpful.
