OK, If you've installed Pegasus, there should be a Pegasus icon on your desktop that looks like PHP's "biting mouth". You've double clicked on that to open Pegasus, right?
Now, when you plug in the Gryphon, look at the status line on the bottom of the Pegasus window: You should see a status of "Connected" in the second panel from the left and your unit's Serial Number (S/N) in the right hand panel.
If you have this picture, you're good to go. Select Updates->Targeted Functions to begin downloading your tunes into the Gryphon. It will take a while and you'll see advisories that tell you what's happening as things progress.
If you've followed these instructions and you still have no joy, then Bill will have to help you.
