Thread: Gryphon issues
Old Wed, March 25th, 2009, 04:46 PM
dsilva584's Avatar
dsilva584 dsilva584 is offline
PHP RULES!!!
dsilva584 is on a distinguished road
Good on you for posting the Vista instructions, xthorxz400. I probably should have done it, but when he said he'd gone through, "the troubleshooting in the instructions for Vista", I thought maybe he'd taken care of that problem. Of course, that could easily be the problem as well.
woops i didn't even see he put that lol dang that speed reading!!!oh well mab the screen shots will help I had this problem and had to use this fix is the only reason why i posted that lol
well in that case try this MACH
bring up your run command by going to start then clicking on run...next type in devmgmt.msc and click ok...this will bring up your device manager...click on the + sign next to "universal serial bus controllers" and you should find your gryphon listed in here "i think it is USB controllers" I will let you know for sure later ....anyhow you should be able to find your gryphon somewhere in the device manager when it is plugged into your computer....once you find your gryphon try to right click and reinstall the driver for it (the driver came with the software you downloaded from PHP)....if you have ever had a "edge" installed on your computer it will almost always come up with the driver for the edge so look for that also...if that is the case right click and uninstall the driver for the edge. when it asks you to delete the driver click yes....you will then need to unplug and replugin your gryphon....you should be able to install the driver that came with the php software. If that doesn't fix your problem try another usb port on your computer or another usb cable. If that does not work go lowes and get the biggest hammer they have.....next take your computer outside and smash it 2 hell...orrrr you could contact PHP...id go with the hammer!!
ps sometimes it helps to disconnect and reconnect your gryphon when looking for it in the device manager
