Old Wed, December 24th, 2008, 10:15 AM
Bill! Thank you, thank you, thank you!!!
Everything's totally clear now (I hope). I've been going into the Custom Options menu every time I've loaded a new tune (switching from Tow to Economy to Stock, depending on need) and now I see my confusion. In the Custom Options menu, the GR and TS information is obtained from the Calibration section and it may be bogus (unless a valid set of numbers had been written there before, and you Load Previous Settings?).
So, whenever changing tunes, Mark. Simply enter the level you want and skip the Custom Options part. Let the PCM accept the new tune. Then, if you need to verify or change anything, go back, reload the same level, enter the Custom Options menu and in it, first thing, Load Previous Settings. Then, change or verify anything you would like to customize your tune, recognizing that for each value you even look at, programming is going to take longer.
Did I get it right, finally, Bill?
The problem is not in your explanation sir, the problem is in the explanation or lack of same in the Edge manual (but I know it's a tricky concept).
