Old Fri, December 26th, 2008, 01:35 AM
jerodr's Avatar
jerodr jerodr is offline
jerodr is on a distinguished road
Well first off you have to switch some ground wires around on the stock mirror harness. Second you have to locate the interior lamp switched power wire under the kick plate(for the puddle lamps). I will go ahead and tell those of you who want to do this mod that the wire is on the driver's side only. It took me about an hour and a half with the test light on the passenger side to figure that out. You have to tap into that wire and run it to both mirrors. Getting the wire through the dash from the drivers side to the passenger side was brutal. The actual wiring is very simple but the logistics of it sucked. They are worth every second of time though!
Jerod
04 Screw Lariat--Magnaflow SI/SO-- PHP Gryphon--AS 2"--BFG ATs 285/65/18--
Silverstar Heads and Fogs
