Old Mon, April 6th, 2009, 12:30 AM
BluByu, I think it's a bit more than this.
Desert Racer, forget the "Load Previous Settings" item for now - you seem to have no valid settings to reload.
Go to Tire Size (TS) and enter your numbers. Make sure you hit <Enter> when done to save those settings. Go to Gear Ratio (GR) and make sure that value is correct also - hit <Enter> to save the correct value.
Then, scroll to the "Done" menu item and hit <Enter> - you should see a prompt to turn the key OFF, then ON again. When the PCM programming is complete, those settings will be saved and when you "Load Previous Settings" in the future, you should not see the 23XX value for TS anymore.
DO NOT hit the <Menu> key diring this process, or you will discard your changes!
Let me know how this works out - PLEASE!
