Originally Posted by axlehead
another question, I had to disconnect the gryphon to install it into the pod on the dash so it showed the hex code again when I installed it. I then went to the power programmer and selected the extreme tune (which is the tune that I uploaded previously) and I accidently said no to custom options and it went through the whole upload again. I just want to make sure that it didn't erase the stock tune that is listed under Return To Stock. Made me a bit paranoid that it may have backed up the extreme tune as stock. Forgive me if this is a stupid question, still learning is all.
Axlehead, I don't think Lars quite understood what you were asking. What you saw when you reconnected the Gryphon was perfectly normal. Then, as I understand it, you wanted to program Level 3 (again), but this time with Custom Options, which you accidentally bypassed - Right?
I this is the case, you simply overwrote your previous Level 3 tune with a new, identical Level 3 tune. You still have your Stock Tune - it was saved when you programmed your PCM the first time around. And, as Lars pointed out, you should now be seeing a "3" in the upper right hand corner of the screen.
