Originally Posted by OneTomcat
Has your Gryphon changed your truck back to stock (level 0)? I know there are issues if the programmer is set to anything but level 0 when you try and connect to the computer.
Try changing the order of connection. If you are running Pegasus and then connecting the unit to the computer, try it the other way, ie, hook everything to the computer and then run Pegasus.
If possible, try a different connection cable. Most any digital camera cable will work as long as the plug is the same size.
The problem with the Gryphon only comes up when your are trying to download the custom tunes, in this case he doesn't seem to be able to get that far.
