Old Tue, April 14th, 2009, 02:14 PM
soutthpaw's Avatar
TIT (Tuner In Training)
It should not take too long if the the chip is in stock... not sure about the Phoenix as it does not seem to be as popular, (I don't know why someone would want a programmer over a shift on the fly chip) but they seem to sell out of the Gryphon as fast as they get them in.... otherwise add a week to get the chip. then when you get the FU upgrade they will send you the burner and the software. Keep in mind that Canned tunes are still dependent on the hex code so there is still probably a half hr of setup time per chip... just a guess but based on doing my phoenix with minotaur software...
Just for example, if you have a non-stock tire size then each of the 6 canned tunes needs to be opened and the tire size value changed and then saved then burned to the chip.... So there is a bit more to it than just putting 6 pre-written tunes onto a chip... Also why it's important to list all of your mods on the order form...
Back after many years.
2003 F250 CC LB 4x4 7.3PSD
Minotaur user.
