Old Fri, April 17th, 2009, 07:30 PM
soutthpaw's Avatar
TIT (Tuner In Training)
You have a couple of options. One is to have the shift points left stock and leave transcommand in. However everything the transcommand does can be done via tuning for the phoenix. U just need to tell Bill exactly what u want the tranny to do and what shifting u want. If you have not installed a shift kit or valve body. I would drfinitely say do that too. If u r towing a lot get the transgo tugger hd. It will give u downhill engine trans braking option too. Check out the minotaur forum as we got some good tranny tuning discussion going on over there. you can even run a different/ better base file with Phoenix. I'm doing that on my truck. Bill can tell you if u have the best base file available or if there is a better option. Then sell the transcommand system on. Ebay or something
ASE Master Auto Technician
2001 Ford Excursion 7.3 4x4
