Old Tue, April 21st, 2009, 11:06 PM
txarsoncop txarsoncop is offline
txarsoncop is on a distinguished road
Jack,
Thanks, you confirmed what I thought I was reading.
Granted I understand fluid dynamics are tricky, tricky. So take my musings below with a grain of salt. But, I live next to a PERFECT example of fluid dynamics gone wrong. Plus being a firefighter and having a master plumber for a father I understand the "common sense" wet side pretty well.
The author of the article was referring to a single cylinder engine and, at first, I thought well that's totally wrong for our 8 cyl application. But then I thought I remembered that with a V8 only 2 cylinders are opening at once correct? So it's not really that much different? Except for a convoluted intake path, a filter media and unexplained holes in both the resonators and intake tube.
If I'm remembering correctly I believe you posited somewhere here that the holes might actually be to remove some of the "springyness."
I rounded the edges of my PVC with the Dremel and a file because it just seemed to make sense. Probably didn't make a difference but...
bill
2005 Screw 4x4 Lariat - mostly stock
1964.5 Mustang - not stock
