Old Wed, April 22nd, 2009, 12:25 AM
soutthpaw's Avatar
TIT (Tuner In Training)
Ok Bill suggested I look at the Inferred Throttle Position map in regards to the Cruise control being to aggressive and also said there are some gain options which ill have to try and figure out myself will also try the cruise accel rate setting modification
Just got the new tunes onto my chip tonite so need to run those for a while and also run some AE data logging before changing anything... need to reseal the front axle and replace the caliper pins with the upgrade kit and fix oil cooler oil leak etc. so it will be a while before i get to trying out any modifications i make to the tunes
ASE Master Auto Technician
2001 Ford Excursion 7.3 4x4
