Thread: Spark Plugs
Old Wed, April 22nd, 2009, 10:10 PM
That $ sounds high usually around $300-$400. Call around even if it's an hour drive away. But on the other hand is the carbon cleaning service being done also? You can do that part yourself just use sea foam or berrymans in the tank for a couple of fill ups.
Most are putting the stock kind back in and following the tsb to the letter. Some have tried aftermarket plugs and did have the best of luck. Brisk has the best aftermarket one out there but be aware a it's not a 100k plug like the stock ones. Stock plugs have the platinum tips and brisk doesn't. So brisk might be a 20-30k plug.
I just want to find 08.5 heads then I won't have to worry about it ever! Or as long as I own it.
