Old Fri, April 24th, 2009, 07:48 AM
Originally Posted by T&Df150 View Post
I've been running E85 with the level 3 tune and just filled up today. I don't think level 2 to will work with E85, last time I tried the check engine light came on and the truck went into limp home mode, or it was just running rough, not sure why, probably tripped the knock sender. I guess I will run this tank out and switch to regular gas and then to level 2 sense it works fine with 87.Tell then Ill take it easy, lol.
The check engine light likely came on due to P0171/174 codes. These are lean codes and the PCM is unable to correct the fuel trims or has to correct more than 15-20% from base. It takes A LOT more E85 per unit of air to compare to gasoline.
