Old Sat, April 25th, 2009, 01:46 PM
DJ,
Wow. Yeah. I see that. For some reason, the TCC isn't being commanded on....when it SHOULD be. Weird. I just drove mine again to see if I could get it to do what your datalog showed. Nope. Mine doesn't do it.
As far as your shift solenoid "issue" goes, there are two shift solenoids in the transmission that control the 4 gears. They work like a logic table. For example:
1 off, 2 off = 4th
1 off, 2 on = 3rd
1 on, 2 off = 1st
1 on, 2 on = 2nd
This goes along with what your AE showed you....SS2 "0" (off) in 4th and "1" (on) in 3rd.
If this parameter is changing when your TC is acting up, then you have a correlation issue between 3-4 and 4-3 shift points.
That's a neat software package you have there, DJ.
EDIT:
I see that the SS2 value changed at frame 143-ish. The TC was acting up before that..... Hmmm.
