Old Tue, December 30th, 2008, 10:00 AM
jerodr's Avatar
jerodr jerodr is offline
jerodr is on a distinguished road
I actually went to oreilly's auto parts website(out of curiosity) and found the tps sensors there for under $50.00 so that's kind of weird if that is true what you say. There are three different one on there though: one for L eng code, 3 eng code, and 5 eng code and it says you must have the right one. I'm not sure how to locate the right one. Last night I went out to my truck and set accelerator pedal position as one of my pids on the gryphon. With my truck in neutral I determined how far I had to push it before the rpms moved at all. I finally came up with 7% accelerator depression before the rpms moved AT ALL. To get the rpms to go up considerably it had to be more around 9-10%. I have a feeling that yours(Jack) is much lower. Hopefully Bill will chime in on this.
Jerod
04 Screw Lariat--Magnaflow SI/SO-- PHP Gryphon--AS 2"--BFG ATs 285/65/18--
Silverstar Heads and Fogs
