here is a table I Just made that compares the Offset at altitude compared to sea level of the stock map as a way to look at different patterns.. I may put these values on a map just to see what it looks like in 3D
The highest advance group is at high RPM in the low to mid throttle range Based on the fact that there is a low mass fuel desired value (found in low torque demand situation).. which would most likely be found at high crusing speed... thus more advance under low load and best fuel efficency
oh the 55/2200 value is a typo, its supposed to be 9 not 90 heh
