Originally Posted by 04FX4
Tried that. I t is not the tq and it also does not show it jumping in and out of gears.
The only time I've ever seen what you're describing here was in 1st gear at idle and it was when I tried advancing the spark by a measly 0.25 degrees. The idle speed started "hunting". I set the spark advance back to zero and it went away. I don't suppose you possibly tried advancing the idle, did you?
And, if not, I wonder what would happen if you retarded the spark by 0.25 degrees in the tune you're using? I'm not saying this is the BEST fix, but any additional information might help Bill adjust things.
